How to: Rebuild Seca II Front Brake Switch
93YamahaSerf
How to: Rebuild Yamaha Seca II Front Brake Switch
I was working on my bike and I noticed that the brake switch was sliding back and forth with a lot of resistance; here's how to fix that problem. This should also remedy a non-working rear brake light if the switch is to blame.
What you'll need:
  • Phillips/flat head screwdriver
  • old brush(tooth brush)
  • soap
  • grease
  • paper towels
The switch is held in place with two Phillips-head screws; remove those screws and then un-plug the connector. The switch should now pull right out.
Once you have the switch off, use a flat-head screwdriver (or butter knife) to carefully pry it apart:
It should split into two pieces, like this:
As it comes apart, be careful not to lose this piece:
Take out all the little parts and be careful not to lose them!
Scrub the parts with a toothbrush and some dish soap:
During reassembly, grease the slider:
But don't go to crazy with the grease. Clean any extra grease off so its just on the pin and spring:
Clip the top switch back together and verify it operates smoothly.
Note, the order of assembly for these parts is as follows: Black pin slides into the hole on the bottom of a cover, put the big spring over the pin once its in the cover, the white piece will compress the spring a little and lock onto the black pin, then drop it into the cover, put the little spring in the white square and the copper contact point over the spring.
'95 Acura Integra LSV-SE. 500 hp build (Daily)
'91 Honda Civic EF (Sold)
'95 Acura Integra (Investment)
'04 Infiniti G35 5AT (Sold)
'93 Yamaha XJ600 (Soon to be Daily)
