How to: Fix a Broken Relay Connector Pin
susho
I have a relay which has a broken pin in the relay housing where the harness plug connects. Rather than buy a new/used one, I repaired it. Here's how:
First, the original pin is broken cleanly with the surface inside the box and cant make contact with the little stub of metal. I began by drilling a hole in the housing next to the broken pin and inserting a short section of wire, which I then soldered to the metal stub.
I then removed the corresponding wire from the harness plug and configured a bullet connector for that circuit which will now be external to the relay. I also removed a small chunk of plastic on the bottom of the plug to clear the new wire and soldered inside the relay.
This repair works fine and saved me some cash.
This topic has 2 replies
