Front Fork Springs
I've found something interesting while doing the maintenance on the '97's fork and while converting the '92 to the FZR front end. Below are three springs and spacers. The top is the spring/spacer removed from my '92's forks. The spacer is aluminum and the spring is linearly wound. The middle is the '97's spring/spacer. These look stock. The bottom is the FZR600 spring and spacer. These also look stock.
I'm thinking I'll stick with the linearly wound spring and aluminum spacer as the '92 had a good feeling fork prior to this work. What do you all think and what does the stock spring/spacer look like in a '92 Seca II?
This topic has 14 replies
