Sump Oil Leak Help
GR98
I have a 98 Xj600s and since changing the oil last season. It started leaking oil into the pipes directly below sump. I ordered new sump gasket. Replaced drain plug/o-ring. First still leaks. Any suggestions? Before I pull sump pan off, it looks like I can drop it with taking pipes off or maybe even with them on
Kurt Carpenter
