Love the site, Float height Q
Squeezer81
Love this site, has helped me alot :) I just got done checking my my float height doing wet method and first 3 carbs are about 5.50mm below mark on bowl 4th carb is about 4.80mm below carb. Question, is that a sign of almost being to rich or to lean? I forgot if fuel level being closer to the outside float bowl mark is lean or if it being far below the float chamber line albeit still within spec 4-6mm as per manual is rich? 96 seca ii 600. Thanks for this awesome site :D
