A little backstory first, I traded this bike for a Buell Blast I dropped, this bike wasn't running. The previous owner took it to a service shop that double filled the oil, guy rode it a mile down the block and it stopped running. It sat for 2 years before I got my hands on it. (insert epiphany moment here) I got the bike running again, rode it a good 200 or so miles, and then yesterday happened.
While riding home from work yesterday, the bike started making really weird noises and was behaving odd. I figured the clutch was going out, as it's sounded horrible and the engagement moved to the very end of the lever, so I figured I'd just take the freeway all the way home and go as fast as I could per traffic conditions. (Which was probably 90-100mph.) This morning, I go out to start it, and it would only idle if I had the throttle pinned at full. It also sounded like a parallel twin.
I'll be honest, I got a little pissed off...
2 hours later, the head is off of the motorcycle.
The head gasket was in really bad shape... the right side of the gasket was separated into individual layers and the packing used in between steel sheet layers was totally gone on both sides. This explains why it sounded like a P-twin, only 2 cylinders had any compression. Today I went down and poked a bit at the parts and pieces of the bike, thinking I needed to check spacing between the pistons and cylinder walls... Here's where I lose it... Cyl 2 and 4 have enough play to grab the valve reliefs and wiggle the piston around, a lot. I walked out of the garage at that point. 1 and 3 feel great, look great, and are probably the two that were working until the right side of the head gasket blew out. This also explains the small clicking I was hearing with the clutch in at idle on the right side of the crankcase.
After looking at the price of parts, I'm just gonna buy a complete engine off of eBay with lower miles, which should be cake as mine has 48k on it...
I'll post pictures when lightnings better.
