Bike stuck in neutral, how can I fix this? What could cause problem?
Slartibartfast
Does the clutch lever move at all? Can you move the bit at the other end of the clutch cable by hand? Does the gear pedal move at all (but not select a gear) or is the pedal stuck?
it's not something I've ever experienced, but the more detail you can provide the more help others may be able to provide
