Oil seal specs + testing vacuum fuel system.
Nickdylan92
Hi there,
(1) Does anyone have the specs of the seal that sits on the countershaft? It's quite a big one behind the front sprocket. My bike is somewhere else so I cannot take it out and look at the dimensions myself. So I hoped somebody here knows the specifications.
(2) The same for the (inner) seal on the "gear rod" which is attached to your shifter. So not the one in the sprocket cover, but the one in the engine.
(3) And my last question: Is there a way to test a leakage in the petcock or fuelpump (both 1992 vacuum type). I tried putting one end in petrol, and sucking on the vacuum end but this did not work.
Thanks in advance,
Nick
Burn rubber, not your soul.
This topic has 8 replies
