RF600 rear wheel conversion.
gavin.starr
I Have been looking at doing the wider rear wheel conversion and it seems simple enough. the numbers below are ebay item numbers that i need some one in the know to have a look at to make sure im ordering the correct parts if possible as any help would be great, I dont really want to be ordering the wrong parts and then having to re order them.
191802589717 torque arm
191802680903 Caliper
252281246760 Caliper bracket
252217880063 Sprocket carrier
221932794981 Cush Rubbers
281914784718 Rear wheel
401065585819 rear sprocket
Still need 3 mm sprocket spacer,
Still need kz400 can’t find?????????
Ninja 250 spacer found.
Im pretty sure i have found all the parts needed apart from the kz400 spacer can any one point me in the right direction?
Gav
This topic has 1 reply
