I have hit the frame with a wire wheel to roughen up the exsisiting paint and to remove all rust and flaking paint particles and it has now been primed ready to paint.
Primer used: Fiddly Bits 250g Grey Primer Spray Paint
http://www.bunnings.com.au/fiddly-bits- ... t_p1580057
Note: I am Painting frame with spray cans
1). So to paint the frame is any paint type ok?
2). i have seen automotive cost at $30AUD is this really required ? (I was just going to use some normal spray paint).
3). This is what i was thinking of "Fiddly Bits 250g Flat Black Spray Paint"
http://www.bunnings.com.au/fiddly-bits- ... t_p1580054
Will this be ok or should a spend the extra for the automotive paint?
Please tell me your thoughts and why?. Thanks
Andrew....
Paint Specs
Model Name Fiddly Bits 250G Flat BlackModel Number428513/250GM
Material: Oil Based Acetone
PaintColour: Flat Black
Indoor: Yes
Outdoor: Yes
Application Method: Aerosol Container
Low Temperature: Yes
Minimum Temperature for Use: 10
Sheen: High Gloss
Splatter Resistant: No
Time Before Recoating: (mins)60
Tintable: No
UV Resistant: No
Recommended Surfaces Ideal for interior and exterior applications.
