Scud misils mounted on my 84-XJ 600, 51J
Trashman
To sad i missed mounting them before new year....Maybe i could reached Japan :o .... Im so sick off spending ouers trying to get it to run.
Since i bought the bike, hasent paid the dude yet, lol...it has newer run properly.
I thought i found the problem when left coil had a crack, bought a new one,sat firing order from left coil 1,4, right coil 2,3 ???
Also tried 1,2,4,3. Spark plugs NGK DR8ES-L, gap 0,7 mm.
Was able to get it ro run a bit, but hevely misfiring got me to turn to my Mikuni BS32 carb.
Did a cleaning, mounted new main jets, adjusted floats to 22, 3 mm, rubber seals seems god, hasent changed float pins ore level.
Mounted back again, even more harder now to get it to fire, tryed with fire gas, petcock seems clean og gas seems to run ok, tryed starting with pri, normal and reserve, oil filter seems ok, a bit wet under, but not much.
So where to go now ???
Any tips who can solve the problem would be helpful, im stuck now, the more i google and read, the more i get frustraded...
:ponder:
This topic has 1 reply
