Hi,
Just been applying some overdue TLC to my recently bought 93 XJ600, one of my (LED) indicators was non flashing but that was tracked down to a snapped resistor wire where it connected to the main loom.
Now however it turns out that the brake light's don't work for the front switch and does not light up for the rear switch unless the brake is pressed full on, did a quick search on the forums and not come up with anything specific, does anyone know of a way to adjust the sensitivity of the rear brake switch ?
Found the brilliant guides for rebuilding the front switch so that's going to get looked at before I try checking the loom for problems.
