Motad Nexus Fitting issues
stuartkeith
Are these a pain to fit? with the old and new engine I am having a night mare. If the down pipes are joined to the silencer I cannot get them to line up in the engine. cylinder 1 sits about 5mm above the exhaust outlet. If I fit all the headers on, then the silencer and collector are about a cm out of alignment on 1 & 2. Is there meant to be a bracket to fit to the rear hanger or dose it just bolt on the inside?
If I fit outside then the rear brake fowls the can.
