Running lights (tail ligt)
kikkerland
Hello everyone. So my Tail running lights are not working.
-Brake lights are working.
-Head lights are working
-Back and front turn signals are working.
Thinking it was the bulb but I switched the cables of the "Running lights" to the cable of the Brake lights and they lit-up when I press on the brakes.
It's the weekend so I cant take it to any auto shop near-by. I was looking at the cable diagram and I saw that the running tail light (BLUE/RED) does a full circuit with the Aux lights in the UK version but I have the US version.
The (BLUE/RED) also runs to the ignition switch and I did convert my ignition switch to toggle (RED connecting to Brown) The (BLUE/RED) is being covered by electric tape. Also You might notice that the ignition switch in the US version only has 3 cables Brown, Red, and BLUE (BLUE converts to BLUE/RED after the plastic clips) .
This is a good video that shows how I connected my toggle.
BROWN and RED.
I'm going to switch back to my old ignition switch to see if that is the problem. Thank you for your help.
We back on line, we came to ride. We stay on the grind until we die
*Cause we can't get enough.
This topic has 1 reply
