Dies after warm up after carb rebuild
nontoxyc
I bought a carb off eBay and ended up having to do a complete tear down soak and rebuild on it. All the passages are clean everything operates smoothly and I believe the floats are set to the right height. As others have mentioned the floats seemed to be set significantly above 8mm. After much cursing I even got the whole thing seemingly correctly assembled. I found the easiest way to remove the Jis screws was by filing two edges to grip with pliers.
On start it idles but a little bit rough then after warm up dies. After 10 minute warm up it will only run with choke fully on at about 4000 rpm.
Any possibility this could be a vacuum leak or the fact I didn't sync before connecting fuel or something minor?
I guess I'll fiddle with it a little more with the bb sync method and ir thermometer. The intake boots don't seem to fit over the carb body at all. Kinda stumped and frustrated with it hahaha.
This topic has 4 replies
