I noticed in other posts that some people bypassed the fuel pump, how do you go about doing this? Also, If I was to check the carb floats, do I just pop off the covers with the carbs still attached to the bike?
I'm assuming that the carb floats need to be adjusted ( I adjusted them using the dry, bench-method.. too, I believe about 7mm) Perhaps, I should adjust them to 8mm?
Any advice on how to properly troubleshoot this issue starting with fuel and then working to ignition would be most appreciated.
