Float Valve Seat Removal
bmdragos
So I'm in the process of cleaning my carbs and its just one thing after the other with things going wrong, stripped screws and all the usual headaches. I finally start making some progress and get to a point where I'm unscrewing the little screw that holds in the float valve seat, I get those buggers out and then go to pull out the float valve seat with a vice grips and nothing, hardly budging. I sprayed them with some PB blaster to see how that worked and I was finally able to get out one of them, but the remaining 3 are really freaking in there!
So whats the deal? Am I really that weak or is there some trick to getting these bad boys out? Thanks!
This topic has 2 replies
