I have a 1992 seca2 The clutch level will not re-engage once its pulled it stays pulled. spring and actuator arm does not pull the wire back. I am wording this as best as I can so please correct me if misuse a term.
I have messed around with the clutch wire setting and it does not affect it. Its almost like something inside the clutch cover is not engaging.
I have taken the cover off and do not see anything visibly wrong.
anything specific I should be aware of?
any help would be sweet. Thanks
Clutch lever won't re-engage
- Zkirby92seca2
- New to XJR
