My XJ stumbles right after startup. What's wrong?
My XJ600 Seca II stumbles when riding right after startup. What's wrong?
If this occurs during the first start of the day when the engine is cold and goes away after a few minutes, this is normal and typical of a Seca II. The Seca II is jetted lean on the pilot-circuit, from the factory, and thus has to warm-up before being rideable. The stock jets are #17.5 and are lean until the bike warms up. If this drives you nuts, you can remedy the situation by installing #20 pilot jets which will improve cold-startup ride-ability and will also help with general ride-ability even when warm.
If this occurs even when warm, it's likely your pilot jets are dirty or partially clogged. Clean the carburetors and, after cleaning, upgrade to #20 pilot jets.
