Hello all, Where do you buy your replacement turn signal bulbs?
The previous owners in their infinite wisdom chose to replace the factory turn signals with cheap flush-mount turn signals in the front and then mini turn signals on the back. I've got each one burned out on the left side. The front is a 12V 23/8W dual filament like a 1157 but with a small clear glass globe and the rear is a 12V 23W single filament but is about the size of a flashlight bulb with a frosted glass globe.
I first tried the local autoparts stores with no luck, they sent me onto radio shack with the same result. I've tried searching online but with dialup internet it's been taking a while to find anything. I was planning on switching back to the factory turn signals for better visibility eventually but now I need to get them working to pass state inspection before I can ride it.
Thanks, Tony
where to buy replacement turnsignal light bulbs?
- TonyKZ1
- Resident Expert
