I bleed my rear brakes, work fine now,
I moved up to the front brake, I filled it with fluid, pulled the handle 3-5 times, held it down, loosened the bleeder screw
and some fluid came out I did this about 3 times then nothing came out at all, so I did it another 5-6 times and still nothing, the reservoir is full of fluid, the bleeder screw is on tightly as I pump the lever.
is there somewhere where there is a broken seal where is allowing air to get into it?
or am I doing it wrong.
I messed with the gear wheel in the reservoir and still nothing.
Front brakes not working after constant bleeding
- 93YamahaSerf
- Lookin' Around
'95 Acura Integra LSV-SE. 500 hp build (Daily)
'91 Honda Civic EF (Sold)
'95 Acura Integra (Investment)
'04 Infiniti G35 5AT (Sold)
'93 Yamaha XJ600 (Soon to be Daily)
