So I finally got round to installing Fzr forks and the dual disc on my 95 XJ600N. I decided to used the stock clip on bars it came with- I put them under the yoke, as to me this was more comfortable. But now I have a huge bundle of wires all scrunched up behind my headlight. Has anyone else encountered this problem and solved it? My only thinking is getting out the wire cutters/solder iron to shorten all my cables. I currently only have one headlight bracket holding up my headlight! I can't fit the other one!
Similarly, as I'm using the stock XJ600N yoke with holes for risers (i.e. 5 hole), can anyone suggest what I use to fill them, considering I no longer need them? Like a riser-hole-plug or such? I'm not sure on the name, and I've tried googling, but can't seem to find any non-RolandSandsDesigns ones here in the UK.
All help appreciated guys!
Many thanks
