Painting a Stripe?
ride92
XJOTM July 2013
XJOTM July 2013
If one where to paint a stripe running down the center line of the bike, how would I go about doing such a task? Should I lay down base color, wait for it to cure (2-3 days) wet sand with 1000-1500, then mask and spray stripe? And then wait for that to cure, wet sand again and spray the clear? Or Should I spray the base color and after it has flashed, spray the clear coat and then wait for it to cure and wet sand then mask and spray the stripe color?
This topic has 7 replies
