Longer Side Stands (Kick Stands) for the XJ600
How-to's related to the Seca II's chassis, frame and swingarm
Kanten wrote:Update:
I recently bought, and mounted, a side stand from a Yamaha FZ600.
It is 30cm long (seems just perfect for the 650R/ER6 shock, maybe it has a bit more angle to it), and besides the little tap on the top of the stand it was a simple straight swap. Also, unlike the first side stand I posted (from the Pre-diversion XJ), this has spring mount attached on the right side and height so I even used the original spring and bolt hardware.
(If you have the original exhausts on, it will hit on the bottom)
Nevertheless, here's a list of different side stand lengths according to various ebay sellers
Yamaha XJ 600 Diversion: 230 mm
Yamaha XJ 600 Pre-diversion: 270 mm (spring mount on the wrong side)
Yamaha FZ 600: 300 mm
Yamaha FZR 600: 230 mm
Yamaha FZR 1000: 230 mm (1989-1995 models at least)
Kawasaki GPZ 750: 260 mm
Yamaha TZR 125: 230 mm
Detonation mystery stand: 260 mm
