Need to get it running better
Tsvallette
Last year I cleaned my carbs the Pinesol way and the carbs worked better so I didn't want to do anything else. But this year I want the engine to run in tip top shape so I am going to dive in and sync the carbs first. Today will start my process by following post in the FAQ section:
http://www.xjrider.com/FAQ/index.php?ac ... artlang=en
Seems straight forward and I should be able to do this by myself. This will save me $75 if all goes well.
After the sync I want to get #20 Pilots jets:
http://www.jcwhitney.com/pilot-jets-vm2 ... ilTabPanel
Will these work with my almost non restrictive exhaust flow and modified air filter or should I go with a bigger size? I've been thinking of just drilling out the current pilot jets and if I screw them up then I can get the new ones. Since I brought this up what size drill bit will I need?
If its too plain then MODIFY!
This topic has 8 replies
