a couple weeks ago, i picked up a 94 seca ii that isnt running.
so far ive replaced the following:
- fuel pump
pet cock
fuel lines
spark plugs
- idles fine (around 1500) with choke open
exhaust pipes 1 and 4 cold
exhaust pipes 2 and 3 very hot
all spark plugs sparking
all carbs fill up with gas
compression is fine
any throttle kills the motor
any change to choke kills the motor
my next step forward is to take the carbs off, take out the mixture screws, make sure they are clean, and the holes are clear.
any other suggestions?
thanks,
-Andrew
