oil leak right side
- docter911
- Lookin' Around
So this sounds simple but it hasnt been. i have an oil leak from the oil fil cap, so i changed the oring. i also have a leak coming from the clutch pulley so i changed the seal, but it still leaks form those spots... at short rides <10min just a small drop on the clutch cover is visible, but on >10min and its usually a 30 min cummute i get so much oil i have to wipe off the entire cover and the fram behind the engine. its really annoying because im getting my pants oily and my boot laces are oily to the touch and i have to periodically fill it with oil. I havent done the valve adjustment yet and the oil is due for a change. any suggestions.
