I've torn down my carbs on a 93' XJ600 and given them a a cleaning. Replaced all the O rings, float needles, gaskets etc.
The bike does start and seems to idle fine. The rpm acceleration doesn't appear to be so responsive, however I am not sure what its supposed to be right.
I noticed that the carb slide diaphrams can be moved with your finger. They do bounce back and slide to the relaxed position.
I don't see any movement when I apply the throttle or at idle. I made sure the diaphrams were clean and lubed with silicon lubricant.
How can I tell the slide diaphrams are working as intended?
