Just checked valves.... Need some THINNN shims?
fortcollinszj
Well this is weird. Just checked and double checked the valve clearences (following instructions in Haynes service manual, lobes facing opposite each other)
Cylinder 4, exhaust: Measured gap of .127mm, pulled out shim .275mm, specs call for a gap of .25mm to .21mm, meaning I would need a shim .151 to .192 to be within spec, the .192 being the edge of the spectrum leaning towards tight.
That seem right? I haven't seen a shim under .200 available in a quick search.
I'm in a little over my head with this, I'm second guessing myself, but I swear I measured correctly with the feeler, but all cylinders are requiring some strange shims.
This topic has 5 replies
