Issues with brake light and hazard lights?
- ride92
- XJOTM July 2013
I am just wondering if the brake light should be coming on when just the rear brake (foot pedal) is depressed? I only get the brake light on when I squeeze the front brake. Is that normal or do I have something going on that I need to fix? Where to start? Also when I turn the key to the hazard light postion, down past lock the front blinkers come on solid, the rear light stays lit but no rear blinkers come on. Again is that how it suposed to be or do I got something funky going on with the electrical system?
