Hi, I have a problem with my idle. Last year, I've got some problem with rust in my tank. So this spring, I washted all (carbs, tank, fuel pump...) since then, I have a problem with the idle, it's always change. I adjust it to 1500rpm and after 5 min ridding, it's change to 2000, 3000rpm... I adjust the valve, carbs sync., change the joint carb and all the fuel line and vacum line and it's change nothing!
What do you think?
Thank
