High Idle
wutname1
So first lets start with where does your bike idle?
So my 92 Seca will normally idle around 1.5k while riding around sitting at a light. However occasionally it will run high around 2-2.5k
I can sometimes get it to go down to 1.5 by doing one of the following:
  • - Letting out the clutch a bit till it catches and brings the RPM down then pull the clutch back in.
    - Push the throttle forward and it will come down.
    - Rev The motor then push the throttle forward before RPM's come back down
Then there are times where none of those work.
To me it seems like the issue could be the throttle cable or the grips whats your opinion? is there somewhere i can adjust the throttle cable? I have yet to look myself never think of it when i have the chance to look....
This topic has 2 replies
