Replacement fuel pickup tube on petcock?
BanditB
Hello all,
I just acquired a 1995 Seca II with a mere 2000 miles on it. It sat full of fuel since 2011 so I'm in process of cleaning the fuel system. The tank was left full of ethanol fuel which destroyed the fuel pickup tube in the tank (attached to the petcock). Is there a source to replace just the tubes with the filter screen? The petcock works perfectly and did not need a rebuild other then the dissolved tubes.
This topic has 3 replies
