Hello. I took my carbs apart soaked them in Pine Sol and put them back together. However I didn't do the "butterfly" shaft seals. The butterfly's and seals sat in carb while the carbs soaked.
Could this cause a deteriorating of the seals and cause a huge vacuum leak?
Also I am not seeing the slides move with the bike idling? Although the idle is really rough I was thinking I should see them move?
When I twist the throttle the bike dies.
Thanks in advance for any help.
