Head Experimenting [Port, Polish, and Other Disasters]
Drapheus
Resident Expert
Resident Expert
In the next coming weeks, myself and a buddy of mine who has some performance headwork knowledge will be experimenting with a Seca II head to see what kind of performance modifications can be done to it.
It is simply to better understand the science behind motorcycle heads and their limits, not because we feel that the Seca II should be any faster. But if we do squeeze out some extra power, then we're doing something right.
Modifications will include:
Image Head porting
Image Head polishing
Image Back cut valve stems
Image Machining head surface for higher compression
There really is not a whole lot to work with on the Seca II head, much less a motorcycle head in general. They're small, fragile, and already designed to perform as best they can. However, after closely examining the head, it might allow some small changes that might make a big difference.
Changes we'd like to see:
Image Small increase in power
Image Throttle response improved
Image Power curve modified, mainly the elimination of flat spots
Stay tuned.
(I will smack the first person who says to just buy a sixteen valve bike. You're missing the point.)
This topic has 17 replies
