andrewed1
- XJ Enthusiast
Front/Rear Disc Bolts
Replacing brake disc and stripped/rounded disc bolt
so had to grind of the head to remove - got the shaft out easily...
## Question do theses bolts have to be a Mushroom head bolt or could a Flange Bolt head work...
Material: Stainless Steel
Product Type: Brake / Caliper
Head Style: Special - Allen Key
Thread Diameter: 8mm
Thread Pitch: 1.25mm
Thread Length: 15mm
Shank Length: 7mm
Head Diameter: 16mm
Head Height: 3mm
Allen Key Size: 6mm
Length: 20mm
This topic has 3 replies
