I have a 96 XJ600 already moded. I added a R1 rear and some Hornet features. After 9 years stoped in the warehouse, i have got it and tryied to restart it. No luck. Carbs leaking and so start. Fuel Pump ceased.
So, this is the start of the "Project Reborn". First cleaning the machine from the outside because it was completly dusty.
Here she is after the bath:
After this, its is time to remove some parts to get to the problem. Fuel Pump and carbs are the first stage.
I cleaned all carbs and got it to start. But started with very erratic, like some cilinders not working properly.
[video][/video]
After many atempts i just got it to a friend of mine to ckeck the carbs and to tune then and Sync.
TO DO LIST :
Check Engine valves
Remove oil Pump noise ( pin )
Change oil and dust Seal from Forks and Refill
Changing the front to place a Hornet 600 Headlight
Repair Master Brake Body, glass broken
Paint master cilinder body
Paint Clutch lever
Maintenance in front brake caliper
Change front Tyre
Change Rear Wheel to FZR600 18*4
Change Rear Tyre to 150/60-18
Paint Rear Swing arm
maintenance in rear master cilinder and caliper
Paint rear caliper arm
paint rear caliper
Paint front tree's
