then i replaced it with some square tube and made some tabs for mounting the new rear shock linkage
after that i widened the swingarm bolt hole to 20mm to take the new vfr bolt. could have made some sleeves for the xj one i ques but this is how i did it
also the vfr nut is too big to get a socket on so i trimmed it down to fit on the xj tabs inside the frame
then i made up a new mount for the top of the shock
to space the arm i used two of the chain side spacers cut down to get my spacing right i left the centre spacer as it is
so thats about it really. ill update with some more pics as i put it all back together over the next few weeks.
