fairing removal? how the...?
kscountryboy
Ok...so I guess I'm dumb. I'm trying to get to my headlight for repair. It won't adjust and looks off center through the lens. It is pointing far right and up a little. I haven't rode at night yet much but would like the option.
So I am trying to get to the headlight assembly to see if it got unscrewed off the adjuster or whatever. I can't, however, get the dang fairing off. I removed the bolts by the tank, inside the fairing down low and the ones up by the windshield. I also removed the four lowest bolts from the windshield. So far it will wiggle but seems to still be attached below the windshield. My screen has rtv under it, for vibration I guess, and I can't tell if there are more screws under the rtv or not without removing all of it. My fairing does not have a tab and bolt under the front either fyi. It's a 1994 model if that helps.
Please help if you can! What is holding me up?
Thanks in advance!
This topic has 14 replies
