This is starting point
New tail light in place
New Delkevic silencer in place
I use these sanding pads to prepare fairings for new paint.These are good in round shapes.Copy paste some info:6x9 mirlon scuff pad uf p1500 gritmirlon is a flexible fiber sanding material which is easy to use on profiled surfaces.synthetic fibrous mesh coated with resin and abrasive flexible easy to use on profiled surfaces aluminum oxide - very fine (vf) maroon silicon carbide - ultra fine (uf) gray 6 x 9 pad or 4 x 10 yd roll phenolic resin bonding can also be used wet . I use it with dishwashing liquid, it removes wax and grease at same time.
One piece done
I have already replace clutch,clutch cable,chain and sprockets.
Now project is started :Mozarkrider: . Have a nice day to all.
